Can't Open Project Window Due to Unsupported Component
I just installed Ignition 8.1.12 to test with, and I can’t open the main window for editing because it contains the Sepasoft Barcode Scanner component which isn’t supported by version 8. How can I remove the component in order to open the designer window?
If you shift + right-click on the window in the tree can you copy the XML to clipboard?
Just tried that, it doesn’t work.
Darn. You might have to delete it in 7.9 and re-import the project or window or something.
Never mind, it turns out they do offer a version for 8.1, doh! I was looking on Sepasoft’s website, but it was sitting in the Inductive Automation downloads page the whole time, lol.
