Can't Open Script Console
Hi All,
Since upgrading to the latest build I’m unable to open the scripting console. This is happening on any machine I connect to the gateway. The exact error is shown below.
I’ve re-installed the current version and rolled back to older builds but the problem remains. Any advice is greatly appreciated - Thanks
Hi Sam, can you upload the AlarmConfigs script? (located within /data/projects/projectName/ignition/script-python)
Do you happen to have any other scripts named ‘system’ or ‘site’?
Hi Kurt,
I removed the AlarmConfigs script from the project and this fixed the issue. I’ve since recreated the script and everything works as it should - Thanks for your help!
