I created a style with a hyphen in it, closed it and then found I couldn’t open it again. I experimented with various style names and discovered that if I had a hyphen or underscore in the name that I couldn’t open them. But if those characters didn’t exist then I could open them:
EG I can open “PanelHeader” and “TheStyle”, but can’t open “Panel-Header” or Panel_Header"
I thought that this was strange, as I have an 8.1.3 installation with the “simplequickstart” project installed, and it has styles with underscores and hyphens in them, and I can open those styles:
I think using a hyphen in the style class is IA’s best practice. I’m on 8.1.16 and don’t see the issue you described. I upgraded from 8.1.15 a little while ago and didn’t see it on that version either.
Win10x64. I had issues the other day where views and styles were doing weird things. I rebooted and it went away. Maybe you have something is la la land.
If you see it happen again, please do - usually in these kind of “it just does nothing” cases there’s actually an error being thrown and trapped, but usually we’re at least putting those into the logs.
