Can't reach Gateway Home Page
Hi All,
I am unable to reach the Gateway Home Page from another computer in the same network and I can’t figure out why :frowning: .
The Gateway I’m trying to connect to has the following IP address 192.168.250.2, I’m in the same class ( 192.168.250.177) and I can ping it.
The option “Allows this Gateway to be discoverable on your local network” is set to TRUE.
Windows Defender is disabled so I don’t think is an Anti-Virus issue.
Windows Network Sharing Options are all set to “Turn On”.
Any thoughts?
are you using port 8088?
192.168.250.2:8088
Yes. Specifically this is the link http://192.168.250.2:8088/main/web/home?0
What about Windows Firewall? Your symptoms are classic firewall behavior.
Yes! It was due to Window Firewall :rage:
Thank you for the suggestion :blush:
I’ll make a new Inbound Rule :wink:
