Can't Resolve Import ProviderConfiguration
Im trying to build a module and im getting build error. could you please guide me in the right direction. Not sure why its having a hard time with the ProviderConfiguration.
A
ny guidance is appreciated.
What does the dependencies section in your pom files look like?
Thanks for moving :slight_smile:
Here is a snap shot
What is the SDK version set to? and what command are you running to build?
Im trying “Maven Install”
<properties>
    <ignition-sdk-version>7.7.1</ignition-sdk-version>
</properties>
Not sure that class existed, at least as part of the SDK, in 7.7. Try version 7.9.3.
That fixed it… is there a reliable way to find out at what version a class was added?
Mmm, not reliably. Are you trying to build a module for 7.7?
not specifically for 7.7, I just wanted to have the minimum i needed to cover all the latest versions.
on a separate note, now that the .modl is created and installed I get an error when opening designer saying missing designer.DesignerHook class. Do I need to have a designer class for a module?
Figured out the issue with designer hook, I had some left over code in build/pom for designer.
Thank you Kevin!
