Not sure if it is my PC but I can’t use thumb wheel on mouse to scroll up and down SQL tags browser in the designer. I am nearly certain I could before. The project browser and OPC browser scroll ok. Is a bit of a problem with many tag folders
Did some testing this morning and tried it on another machine but still the same problem. I then installed 7.5.1 64 bit on one of the machines and it is scrolling fine. Once I upgrade to 7.5.2 64 bit I see the issue.
Both of the machines I tested on are win 7 professional 64 bit machines one has Java 6 and one has Java 7 and both display the same behavior. Attached is the export of the SQL tags I used to recreate the issue
I have had the same issue as well with Version 7.5.4. Scrolling is disabled unless you are directly over the scroll bar in the SQL tags window. Works everywhere else though.
