Can't select Pipes from pipe drawing tool to center components?
Coworker made a PID drawing on a XY Coordinate container. The container is smaller than the HMI resolution so there is a bunch of empty. End goal is if we can either stretch the view horizontally or at least center it.
I looked at the Horizontal Menu component but didn't see any options there for how the view opens, I tried all the options on "Corner Priority" on the view/URL configuration but that didn't seem to do anything. The last and what I thought would be the easiest thing, would be to make the container the right size, select all the components and then horizontally align them via the button, but he used the pipe drawing tool and apparently those are not selectable so that way is currently not viable.
Any ideas on how to resolve this?
On the XY Coordinate container with the pipes, can you set the mode prop to percent?
This should stretch the contents of the container when the container itself is stretched to a bigger size.
