Can't set up Tag Historian. Logs
Trying to set up tags to log and I get the following…
java.lang.Exception: Error running query: CREATE TABLE sqlth_drv (`id` int NOT NULL AUTO_INCREMENT,`name` varchar(255),`provider` varchar(255),PRIMARY KEY (`id`))
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:140)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.createTable(DBTableSchema.java:109)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.verifyAndUpdate(DBTableSchema.java:91)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.checkTables(TagHistoryDatasourceSink.java:1110)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:237)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.lambda$initialize$0(TagHistoryDatasourceSink.java:249)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: java.sql.SQLException: No database selected
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
Do you have a database connection created?
I changed connection string from
jdbc:mysql://localhost:3306/?user=root
to
jdbc:mysql://localhost:3306/MES
