To upgrade… I used the Gateway Control Utility.
Here is a copy of the Ignition.conf file.
Wrapper License Properties (Ignored by Community Edition)
#include ./wrapper-license.conf
Wrapper Java Properties
Java Application
wrapper.java.command=java
Tell the Wrapper to log the full generated Java command line.
#wrapper.java.command.loglevel=INFO
Java Main class. This class must implement the WrapperListener interface
or guarantee that the WrapperManager class is initialized. Helper
classes are provided to do this for you. See the Integration section
of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
Java Classpath (include wrapper.jar) Add class path elements as
needed starting from 1
wrapper.java.classpath.1=./lib/wrapper.jar
wrapper.java.classpath.2=./lib/annotations-api.jar
wrapper.java.classpath.3=./lib/catalina.jar
wrapper.java.classpath.4=./lib/catapult.jar
wrapper.java.classpath.5=./lib/el-api.jar
wrapper.java.classpath.6=./lib/log4j-1.2.15-min.jar
wrapper.java.classpath.7=./lib/servlet-api.jar
wrapper.java.classpath.8=./lib/slf4j-api-1.5.3.jar
wrapper.java.classpath.9=./lib/slf4j-log4j12-1.5.3.jar
wrapper.java.classpath.10=./lib/tomcat-coyote.jar
wrapper.java.classpath.11=./lib/tomcat-juli.jar
wrapper.java.classpath.12=./lib/wicket-extensions-1.4.1.jar
wrapper.java.classpath.13=./lib/wicket-1.4.1.jar
Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=./lib
Java Bits. On applicable platforms, tells the JVM to run in 32 or 64-bit mode.
wrapper.java.additional.auto_bits=TRUE
Java Additional Parameters
#wrapper.java.additional.1=-Xdebug
#wrapper.java.additional.2=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
Initial Java Heap Size (in MB)
wrapper.java.initmemory=256
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=1024
Application parameters. Add parameters as needed starting from 1
wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
wrapper.shutdown.timeout=120
wrapper.jvm_exit.timeout=120
Wrapper Logging Properties
Enables Debug output from the Wrapper.
wrapper.debug=TRUE
Format of output for the console. (See docs for formats)
wrapper.console.format=PM
Log Level for console output. (See docs for log levels)
wrapper.console.loglevel=INFO
Log file to use for wrapper output logging.
wrapper.logfile=./wrapper.log
Format of output for the log file. (See docs for formats)
wrapper.logfile.format=LPTM
Log Level for log file output. (See docs for log levels)
wrapper.logfile.loglevel=INFO
Maximum size that the log file will be allowed to grow to before
the log is rolled. Size is specified in bytes. The default value
of 0, disables log rolling. May abbreviate with the ‘k’ (kb) or
‘m’ (mb) suffix. For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=1m
Maximum number of rolled log files which will be allowed before old
files are deleted. The default value of 0 implies no limit.
wrapper.logfile.maxfiles=5
Log Level for sys/event log output. (See docs for log levels)
wrapper.syslog.loglevel=NONE
Wrapper Windows Properties
Title to use when running as a console
wrapper.console.title=Ignition Gateway
Wrapper Windows NT/2000/XP Service Properties
WARNING - Do not modify any of these properties when an application
using this configuration file has been installed as a service.
Please uninstall the service before modifying this section. The
service can then be reinstalled.
Name of the service
wrapper.ntservice.name=Ignition
Display name of the service
wrapper.ntservice.displayname=Ignition Gateway
