Ok Guys… I hate to bother you on this one… because I may have caused it… but I wanted to check before I uninstalled and restarted.
I am getting the same Can’t Start Gateway problems. I have followed this thread … deleted the files and still have the problem.
It all started right after I downloaded the Modbus Module and tried to install. I got a error Message on that install. Something about connection could not be found at 127.0.0.1.1000… so I tried to install the module again… with the same error. Once I refreshed the Module page… It showd Modbus Status as NEW … all the other Modules were at a Status of Running. So… I thougt maybe I needed to restart the gateway… so once I did that… thats when it all went south. I am almost sure that the Modbus thing is really unrelated… but just wanted to tell you what I was up too during that time.
So after many attemps… I thought… maybe it just be best if I upgraded to the latest version. Well… that didnt help either… so now I am back… asking for help from the masters. Carl, Colby or any others got any ideas?
Attached is my lattest error log. It appears the problem is with the internal database… missing a file or something…
Tyler
Log session start time Mon Apr 05 13:14:47 EDT 2010
Time Level Message Category Thread
Apr 5, 2010 01:14:47 PM WARN Unable to clean temp dir: java.io.IOException: Unable to delete file: C:\WINDOWS\TEMP\ignition_main_tmp\xopc2193846989659594941.jar com.inductiveautomation.ignition.gateway.bootstrap.SRFilter Thread-10
Apr 5, 2010 01:14:47 PM INFO SRClassLoader init com.inductiveautomation.ignition.gateway.bootstrap.SRClassLoader Thread-10
Apr 5, 2010 01:14:52 PM INFO Ignition["/main", state=STOPPED] ContextState = STARTING com.inductiveautomation.ignition.gateway.SRContext Thread-10
Apr 5, 2010 01:14:52 PM INFO Starting Ignition 7.0.7 (b4829) com.inductiveautomation.ignition.gateway.SRContext Thread-10
Apr 5, 2010 01:14:52 PM INFO Reloading JDBC classloader. com.inductiveautomation.ignition.gateway.SRContext Thread-10
Apr 5, 2010 01:14:52 PM INFO Creating SecureRandom object… com.inductiveautomation.ignition.common.util.SecureRandomProvider Thread-10
Apr 5, 2010 01:14:52 PM INFO Generating seed… com.inductiveautomation.ignition.common.util.SecureRandomProvider Thread-10
Apr 5, 2010 01:14:52 PM INFO … Seed Created. com.inductiveautomation.ignition.common.util.SecureRandomProvider Thread-10
Apr 5, 2010 01:14:52 PM INFO … SecureRandom Created. com.inductiveautomation.ignition.common.util.SecureRandomProvider Thread-10
Apr 5, 2010 01:14:52 PM INFO [SRContext] init: Wicket core library initializer org.apache.wicket.Application Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()] org.apache.wicket.RequestListenerInterface Thread-10
Apr 5, 2010 01:14:52 PM INFO [SRContext] init: Wicket extensions initializer org.apache.wicket.Application Thread-10
Apr 5, 2010 01:14:52 PM INFO ClusterState = CONNECTING com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:14:52 PM INFO [SRContext] Started Wicket version 1.4.5 in deployment mode org.apache.wicket.protocol.http.WebApplication Thread-10
Apr 5, 2010 01:14:52 PM INFO JGroups version: 2.6.3.GA org.jgroups.JChannel ExecEngine-thread-1
Apr 5, 2010 01:14:53 PM INFO ClusterState = JOINING com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:14:53 PM WARN Could not read license from HASP key. com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:14:56 PM INFO Starting up… com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:14:56 PM INFO Looking for existing internal database “settings”… com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:07 PM WARN … internal database “settings” corrupted, will re-create. com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
java.sql.SQLException: Database lock acquisition failure: lockFile: org.hsqldb.persist.LockFile@e236cb2c[file =C:\Program Files\Inductive Automation\Ignition\contexts\main\db\settings.lck, exists=true, locked=false, valid=false, ] method: checkHeartbeat read: 2010-04-05 17:15:06 heartbeat - read: -5266 ms.
at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
at org.hsqldb.jdbc.JDBCConnection.(Unknown Source)
at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
at org.hsqldb.jdbc.JDBCDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(Unknown Source)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.dbExists(HSQLDBManager.java:308)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.startupInternal(HSQLDBManager.java:220)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.startup(HSQLDBManager.java:136)
at com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl.setup(LocalDBManagerImpl.java:122)
at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:583)
at com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl.startup(ClusterManagerImpl.java:311)
at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:497)
at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:168)
at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:372)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: lockFile: org.hsqldb.persist.LockFile@e236cb2c[file =C:\Program Files\Inductive Automation\Ignition\contexts\main\db\settings.lck, exists=true, locked=false, valid=false, ] method: checkHeartbeat read: 2010-04-05 17:15:06 heartbeat - read: -5266 ms.
at org.hsqldb.error.Error.error(Unknown Source)
at org.hsqldb.persist.LockFile.newLockFileLock(Unknown Source)
at org.hsqldb.persist.Logger.acquireLock(Unknown Source)
at org.hsqldb.persist.Logger.openPersistence(Unknown Source)
at org.hsqldb.Database.reopen(Unknown Source)
at org.hsqldb.Database.open(Unknown Source)
at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
at org.hsqldb.DatabaseManager.newSession(Unknown Source)
… 22 more
Apr 5, 2010 01:15:14 PM WARN Unable to clear faulted database. com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
java.io.IOException: Unable to delete file: C:\PROGRA~1\INDUCT~1\Ignition\contexts\main\db\settings.app.log
at org.apache.commons.io.FileUtils.forceDelete(FileUtils.java:1390)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.forceClearDirectory(HSQLDBManager.java:429)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.backupFaultedAndClear(HSQLDBManager.java:205)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.startupInternal(HSQLDBManager.java:230)
Apr 5, 2010 01:15:18 PM WARN Unable to clear faulty database “internal database “settings””, disabling autobackups. com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.startup(HSQLDBManager.java:143)
Apr 5, 2010 01:15:18 PM WARN Unable to restore from autobackups because none were found. com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM ERROR Startup of internal database “settings” failed, autobackups disabled. com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO DBManager shutting down… com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Deregistering JDBC driver: class org.hsqldb.jdbc.JDBCDriver com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO DBManager shut down in 0ms com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM WARN Shutting down cluster due to exception during startup. com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl ExecEngine-thread-1
com.inductiveautomation.ignition.gateway.localdb.hsql.DBStartupException: Error loading internal database “settings”
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager.startup(HSQLDBManager.java:188)
Caused by: java.io.IOException: Unable to delete file: C:\PROGRA~1\INDUCT~1\Ignition\contexts\main\db\settings.app.log
… 14 more
Apr 5, 2010 01:15:18 PM INFO ClusterState = LEAVING com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Ignition["/main", state=STARTING] ContextState = STOPPING com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Ignition Gateway shutting down… com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO ModuleManager shutting down… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module fpmi… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module fpmi completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module help… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module help completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module fsql… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module fsql completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module opccom… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module opccom completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module xopc-drivers… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module xopc-drivers completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module modbus-driver… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module modbus-driver completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutting down module xopc… com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Shutdown of module xopc completed in 0 ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO ModuleManager shut down in 0ms com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Ignition Gateway shut down in 0ms com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO ClusterState = DISCONNECTED com.inductiveautomation.ignition.gateway.cluster.ClusterManagerImpl ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM INFO Ignition["/main", state=STOPPING] ContextState = STOPPED com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
Apr 5, 2010 01:15:18 PM ERROR Error during context startup. com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
… 14 more
Apr 5, 2010 01:15:18 PM INFO Ignition["/main", state=STOPPED] ContextState = FAULTED com.inductiveautomation.ignition.gateway.SRContext ExecEngine-thread-1
