Started having errors today, with all Tags not writing. The console is full of the following:
Time Logger Message 10:34:45 AM com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl Cannot create autobackup for internal database “settings”.
java.sql.SQLException: java.lang.OutOfMemoryError
at org.hsqldb.jdbc.Util.sqlException(Util.java:392)
at org.hsqldb.jdbc.Util.sqlException(Util.java:227)
at org.hsqldb.jdbc.JDBCStatement.fetchResult(JDBCStatement.java:1830)
at org.hsqldb.jdbc.JDBCStatement.executeUpdate(JDBCStatement.java:207)
at org.apache.commons.dbcp.DelegatingStatement.executeUpdate(DelegatingStatement.java:228)
at com.inductiveautomation.ignition.gateway.localdb.hsql.HSQLDBManager$AutoBackupDaemon.run(HSQLDBManager.java:619)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:573)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.hsqldb.HsqlException: java.lang.OutOfMemoryError
at org.hsqldb.error.Error.error(Error.java:111)
at org.hsqldb.result.Result.newErrorResult(Result.java:1057)
at org.hsqldb.StatementCommand.execute(StatementCommand.java:208)
at org.hsqldb.Session.executeCompiledStatement(Session.java:1339)
at org.hsqldb.Session.executeDirectStatement(Session.java:1216)
at org.hsqldb.Session.execute(Session.java:1002)
at org.hsqldb.jdbc.JDBCStatement.fetchResult(JDBCStatement.java:1822)
… 13 more
Caused by: java.lang.OutOfMemoryError
at java.util.zip.Deflater.deflateBytes(Native Method)
at java.util.zip.Deflater.deflate(Unknown Source)
at java.util.zip.DeflaterOutputStream.deflate(Unknown Source)
at java.util.zip.DeflaterOutputStream.write(Unknown Source)
at java.util.zip.GZIPOutputStream.write(Unknown Source)
at org.hsqldb.lib.tar.TarFileOutputStream.write(TarFileOutputStream.java:199)
at org.hsqldb.lib.tar.TarFileOutputStream.writeBlock(TarFileOutputStream.java:225)
at org.hsqldb.lib.tar.TarGenerator$TarEntrySupplicant.write(TarGenerator.java:632)
at org.hsqldb.lib.tar.TarGenerator.write(TarGenerator.java:232)
at org.hsqldb.lib.tar.DbBackup.write(DbBackup.java:299)
at org.hsqldb.persist.Logger.backup(Logger.java:1884)
at org.hsqldb.StatementCommand.getResult(StatementCommand.java:279)
at org.hsqldb.StatementCommand.execute(StatementCommand.java:206)
… 17 more
(I) 10:34:44 AM hsqldb.db.HSQLDB2AF197DF72.ENGINE Initiating backup of instance ‘settings’ (I) 10:34:44 AM hsqldb.db.HSQLDB2AF197DF72.ENGINE dataFileCache commit start (I) 10:34:44 AM com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl Creating auto-backup of internal database “settings”… 10:32:44 AM com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl Cannot create autobackup for internal database “settings”.
Any ideas?
