We are finding when using a carousel view, and then clicking the dots to switch between views, after the first click the carousel will switch back to the view previously, if you then click again it will switch correctly.
we are running 8.0.6 and 8.0.5 on two gateways and both are showing the same behaviour
behaviour works fine in preview mode in the designer, its only when viewing the carousel on a webpage
