I have a stored procedure in MS SQL 2005 that return a result. I tried to get the return value with runUpdateQueryGetKey, runPrepStmtGetKey and runPrepStmt. But I couldn’t get the result. How can I get it? Let say, I have a table with two columns. One is ID and another one is code. so that stored procedure will be like this:
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE PROCEDURE [dbo].[testsp]
@CODE AS VARCHAR(4)
AS
SET NOCOUNT ON;
INSERT INTO TEST (CODE)
VALUES
(@CODE);
IF @@ERROR = 0
RETURN @@IDENTITY
ELSE
RETURN(-1)
SET NOCOUNT OFF;
GO
SET ANSI_NULLS OFF
GO
SET QUOTED_IDENTIFIER OFF
GO
In this case, I want to know that the return value is -1 or not to execute the another stored procedure. Please help me. Thanks.
