This will highlight the row, but it’s inefficient, as it has to extract the column for every cell.
config = {'foreground': 'black', 'background' : 'white'}
data = self.data
testColName = 'ColumnName'
testColIndex = data.getColumnIndex(testColName)
testColList = data.getColumnAsList(testColIndex)
testValue = data.getValueAt(rowIndex, testColName)
if testColList.count(testValue) > 1:
config['background'] = 'yellow'
return config
I’d recommend limiting the highlight it to the specific column, as then you don’t have to run the check for every cell:
if colName == 'String Column':
data = self.data
testColList = data.getColumnAsList(colIndex)
if testColList.count(value) > 1:
return config
You could also do this on a propertyChange event. If your table data is coming from a query, add select 0 as duplicate to your query. Then in the property change event
if event.propertyName == 'data':
table = system.dataset.toPyDataSet(event.source.data)
uniqueData = []
for i,row in enumerate(table):
value = table.getValueAt(i,'yourColumnToTest')
if value in uniqueData:
isDuplicate = 1
else:
uniqueData.append(value)
isDuplicate = 0
table = system.dataset.setValue(table,i,'duplicate',isDuplicate)
event.source.data = table
This will only update when the table data changes. Then in your configureCell function,
data = self.data
if data.getValueAt(rowIndex,'duplicate'):
return {'background':'yellow'}
You can hide the duplicate column in table customizer. This code only highlights the duplicate values, and not the first instance of the duplicate values
it works.
I found the data.getColumnAslist(ColIndex) don't have explain in the manual ,
https://docs.inductiveautomation.com/display/DOC79/Datasets
i use print know how it works finally
The .getColumnAsList() method is particular to the BasicDataset class and its subclasses, not part of the Dataset interface. Fortunately, most datasets in Ignition inherit from BasicDataset, so you aren’t likely to find one where it doesn’t exist.
Dear Jordan:
previous you give me feedback on how to check one column whether there have the same data, now the situation is a little difference
you can see the picture, there are 2 lines, my request is if the two column have the same data , the color will become yellow, how to scripting it, thanks a lot.
here is current code:
if colName == 'SerNum':
data = self.data
ColName = 'SerNum'
ColIndex = data.getColumnIndex(ColName)
ColList = data.getColumnAsList(ColIndex)
Value = data.getValueAt(rowIndex, ColName)
if ColList.count(Value) > 1:
return config
data = self.data
if data.getValueAt(rowIndex, 'yourColOneName') == data.getValueAt(rowIndex, 'yourColTwoName'):
return config
Check for duplicate rows using data in two columns:
# Column name of primary value
colName1 = 'ColumnName1'
# Column name of secondary value
colName2 = 'ColumnName2'
if colName == colName1:
data = self.data
# Get column indexes
colIndex1 = data.getColumnIndex(colName1)
colIndex2 = data.getColumnIndex(colName2)
# Get column lists
colList1 = data.getColumnAsList(colIndex1)
colList2 = data.getColumnAsList(colIndex2)
if colList1.count(value) > 1:
# Get all indexes of primary value
indexList = [index for index, item in enumerate(colList1) if item == value]
# Create list of secondary values using indexes we just created
compareList = [colList2[x] for x in indexList]
# get secondary value
compareItem = data.getValueAt(rowIndex, colIndex2)
# Check for duplicates of secondary value
if compareList.count(compareItem) > 1:
return config
