Cell Coloring using Style
Hello everyone,
I am trying to change the color of a cell in a perspective table based on the value of two columns.
Currently, I am doing this in the script mapping of data property binding. The script is:
	output_json = []
	style_red = {"backgroundColor": "#D9000099"}
	style_green = {"backgroundColor": "#9ED23E"}
	style_yellow = {"backgroundColor": "#F4F03D"}
	for row in range(value.getRowCount()):
		row_object = {}
		for col in value.getColumnNames():
			cell_object={}
			cell_style={}
			cell_object['value']=value.getValueAt(row,col)
			if col == 'process_value':
				if value.getValueAt(row,col)>=value.getValueAt(row, 'low_limit') and value.getValueAt(row,col)<= value.getValueAt(row, 'high_limit'):
					cell_style= style_green
				elif value.getValueAt(row,col)>value.getValueAt(row, 'high_limit'):
					cell_style= style_red
				elif value.getValueAt(row,col)<value.getValueAt(row, 'low_limit'):
					cell_style= style_yellow
			cell_object['style']=cell_style
			row_object[col]=cell_object
		output_json.append(row_object)
	return output_json
However, this code cannot be generalized as I have multiple views and I would like to have this script in a single location that I can call for each time. For colors also I would like to use style.
I was thinking to use the combination of message handlers and style but I would like to know your suggestion that? what would be the best way to approach this?
Thank you!
I dont think you need to use message handelers for this.
You can use style classes:
style_red = {"classes": "pathToStyleClassRed"}
If you are using the same if fuctions (with columns low/high_limit) you could make it a project script.
But generalizeing a dyanmic if-statement for different conditions and results is not all the simple
Thank you very much, Victor.
Appreciate it.
