Center align columns in a XY Chart
Anyone know why I can't center the columns in my chart?
I've looked everywhere on the forums and docs and can't figure it out.
One series is too high, and one is too low.
The y data is just a name for each series.
So the data itself shouldn't be creating the difference.
how did you bind the data to this component?
I don't think the binding itself would affect how it's displayed right?
It sets the data to be a dataset like any XY Chart
There's a column called 'name'
And for the above there are 4 different names in the dataset (say A, B, A_Notes, B_Notes)
Wouldn't this be a setting in the chart itself?
Not sure if we have access to amchart-specific settings from within perspective
not sure is related,
In XY chart when X-axis content overlap or is not well aligned I switch it to Y-axis for better readibility
You may try do so if see the graph looks better.
that's what my chart is already set to?
the bars are horizontal not vertical
see your bars are evenly separated
but mine are all mismatched
so this hidden setting seems to somewhat help?
it doesn't seem like I can use it to simply center each series
but it moved it in a way that makes it look less bad
You may try touch XY parameters until you get something you like or start over step by step making sure it keeps the right format.
pretty sure this is just a looked over feature
can you show me a stacked column chart on your end without the varying distances?
Never did stacked column chart.
this one I did using 3 different series
ok but that's not what i'm doing
it needs to be a stacked horizontal chart
