Central Ignition Gateway v. 8.1 getting tag configuration from a version 7.9 Edge
I'm trying to execute system.tag.getConfiguration(tagpath_of_v7.9_edge_gateway, False) on a version 8.1 Ignition gateway. However, I'm getting the error below. Is there a way to sort this out?
14:06:30.246 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - Error executing script for event: propertyChange
on component: OPC Path Text Field.
com.inductiveautomation.ignition.common.script.JythonExecException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.UnsupportedOperationException: Tag editing is not available when targeting an older gateway.
at org.python.core.Py.JavaError(Py.java:547)
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.getConfigurationImpl(ClientTagUtilities.java:97)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.getConfiguration(AbstractTagUtilities.java:116)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:540)
at org.python.core.PyObject.call(PyObject.java:477)
at org.python.core.PyObject.call(PyObject.java:481)
at org.python.pycode._pyx76.f$0(event:propertyChange:26)
at org.python.pycode._pyx76.call_function(event:propertyChange)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:800)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:206)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:312)
Caused by: org.python.core.PyException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.UnsupportedOperationException: Tag editing is not available when targeting an older gateway.
... 32 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.UnsupportedOperationException: Tag editing is not available when targeting an older gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:945)
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.getConfigurationImpl(ClientTagUtilities.java:94)
... 30 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: java.lang.UnsupportedOperationException: Tag editing is not available when targeting an older gateway.
at java.util.concurrent.CompletableFuture.reportGet(null)
at java.util.concurrent.CompletableFuture.get(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.TagProviderRpc.getTagConfigs(TagProviderRpc.java:327)
at jdk.internal.reflect.GeneratedMethodAccessor332.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:225)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(null)
Buried in there is your answer, unfortunately.
Hi Kevin, is there another way of getting tag datatype from an older gateway? Correct me if I’m wrong, but system.tag.getConfiguration is not editing the tags. I wonder why I’m getting “Tag editing is not available…”.
Cheers.
It’s less about editing and more about being wholly unable to deal with adapting the way tags are defined in 7 vs 8 via in the GAN services. There’s a bunch of operations that all fail with the same message, even if it’s a little inaccurate in this case.
If you just need the datatype for a single (or multiple) tag maybe something like this will work:
system.tag.readBlocking(["[default]TestInt.dataType"])
(append .dataType to the end of the Tag Paths, basically)
