Hi There,
is it possible to center the time series chart in its own “container”. The chart seems to be of center and I can not find any property to change the position of the chart relative to the timeRange.
Hi There,
Can you post the JSON for the chart? In the Project Tree, right-click on the chart, Copy and paste it in here. Then be sure to select it and hit the </> code formatting button.
Here it is:
"type": "ia.chart.timeseries",
"version": 0,
"props": {
"series": [
"name": "soll_ist"
"plots": [
"trends": [
"visible": true,
"type": "line",
"series": "soll_ist",
"interpolation": "curveLinear",
"breakLine": true,
"stack": true,
"radius": 2,
"axis": "soll_ist",
"columns": [
"key": "soll",
"color": "#DE0117",
"styles": {
"normal": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"highlighted": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"selected": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"muted": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"key": "ist",
"color": "#16C607",
"styles": {
"normal": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"highlighted": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"selected": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"muted": {
"stroke": {
"color": "",
"width": null,
"dashArray": null,
"opacity": null
"fill": {
"color": "",
"opacity": null
"baselines": []
"axes": [
"name": "soll_ist",
"min": "",
"max": "",
"alignment": "left",
"width": 60,
"label": {
"visible": true,
"text": "",
"offset": 0,
"font": {
"color": "",
"size": 10
"style": {
"classes": ""
"tick": {
"color": "",
"count": "Auto",
"label": {
"format": "Auto",
"font": {
"color": "",
"size": 10
"style": {
"classes": ""
"style": {
"classes": ""
"style": {
"classes": ""
"markers": [
"visible": true,
"type": "line",
"axis": "soll_ist",
"value": 0,
"line": {
"color": "",
"width": 1,
"opacity": 0.5,
"dashArray": 0,
"label": {
"text": "",
"position": "right",
"font": {
"color": "",
"size": 10
"style": {
"classes": ""
"style": {
"classes": ""
"timeAxis": {
"visible": false
"timeRange": {
"dateFormat": "None"
"legend": {
"position": "left"
"meta": {
"name": "TimeSeriesChart"
"position": {
"grow": 1
"custom": {
"key": [
"aggregate": "LastValue",
"alias": "soll"
"alias": "ist"
"propConfig": {
"custom.key[1].path": {
"binding": {
"type": "expr",
"config": {
"expression": "\"[default]\"+{view.params.path}+\"/menge_ist\""
"props.series[0].data": {
"binding": {
"type": "tag-history",
"config": {
"dateRange": {
"mostRecent": "4",
"mostRecentUnits": "HOUR"
"returnSize": {
"type": "FIXED",
"numRows": "100"
"tags": "{this.custom.key}",
"returnFormat": "Wide",
"polling": {
"enabled": false,
"rate": "30"
"aggregate": "MinMax",
"valueFormat": "DATASET",
"ignoreBadQuality": false,
"preventInterpolation": false,
"enableValueCache": true,
"avoidScanClassValidation": true
"custom.key[0].path": {
"binding": {
"type": "expr",
"config": {
"expression": "\"[default]\"+{view.params.path}+\"/menge_soll\""
