I am having trouble establishing a Gateway Network connection on a specific machine; other machines are working as intended. This one however has "Unknown" listed for the gateway name and local certificate and I never see a request come through on the other end of the gateway network.
I stopped the Ignition service, and removed the file in the webserver folder; and then restarted the Gateway; it attempts to restart the service and then almost immediately transitions to "stopped" service. It would not function again until I removed the newly created file and replaced it with the old copy, then it would take off again. I have included the wrapper log below from when I stopped the Ignition service until the failed restart attempt.
STATUS | wrapperm | 2024/01/17 12:30:32 | Ignition service stopped.
STATUS | wrapperm | 2024/01/17 12:30:58 | Starting the Ignition service...
STATUS | wrapper | 2024/01/17 12:30:58 | --> Wrapper Started as Service
STATUS | wrapper | 2024/01/17 12:30:58 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2024/01/17 12:30:58 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2024/01/17 12:30:58 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2024/01/17 12:30:58 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2024/01/17 12:31:00 | Launching a JVM...
INFO | jvm 1 | 2024/01/17 12:31:00 | WrapperManager: Initializing...
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,658 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,705 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,705 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,705 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,721 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2024/01/17 12:31:00 | 12:31:00,721 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | wrapperm | 2024/01/17 12:31:03 | Waiting to start...
STATUS | wrapperm | 2024/01/17 12:31:04 | Ignition service started.
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,804 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7692e1a8 - Driver name=SQLite JDBC
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,804 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7692e1a8 - Driver version=3.39.2.0
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,804 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7692e1a8 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,820 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@60c200c0 - Registering current configuration as safe fallback point
INFO | jvm 1 | 2024/01/17 12:31:08 | 12:31:08,851 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@3e8f139f - Propagating INFO level on Logger[ROOT] onto the JUL framework
INFO | jvm 1 | 2024/01/17 12:31:08 | W [WebResourceManagerImpl ] [17:31:08]: Unable to read "gateway.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2024/01/17 12:31:09 | I [g.WebServerManager ] [17:31:08]: Starting setup
INFO | jvm 1 | 2024/01/17 12:31:09 | I [g.WebServerManager ] [17:31:08]: Setup complete
INFO | jvm 1 | 2024/01/17 12:31:09 | I [g.WebServerManager ] [17:31:09]: Starting up
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.e.j.s.Server ] [17:31:09]: jetty-10.0.13; built: 2022-12-07T20:13:20.134Z; git: 1c2636ea05c0ca8de1ffd6ca7f3a98ac084c766d; jvm 11.0.17+8-LTS
INFO | jvm 1 | 2024/01/17 12:31:09 | 12:31:09,721 |-INFO in ch.qos.logback.classic.servlet.LogbackServletContainerInitializer@25dacdb0 - Due to deployment instructions will NOT register an instance of class ch.qos.logback.classic.servlet.LogbackServletContextListener to the current web-app
INFO | jvm 1 | 2024/01/17 12:31:09 | W [o.e.j.u.DeprecationWarning ] [17:31:09]: Using @Deprecated Class org.eclipse.jetty.servlet.listener.ELContextCleaner
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.e.j.s.s.DefaultSessionIdManager] [17:31:09]: Session workerName=node0
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.Application ] [17:31:09]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.RequestListenerInterface] [17:31:09]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.Application ] [17:31:09]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2024/01/17 12:31:09 | I [IgnitionGateway ] [17:31:09]: Ignition[state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2024/01/17 12:31:09 | I [IgnitionGateway ] [17:31:09]: Starting Ignition 8.1.25 (b2023021409)
INFO | jvm 1 | 2024/01/17 12:31:09 | I [IgnitionGateway ] [17:31:09]: Reloading JDBC classloader.
INFO | jvm 1 | 2024/01/17 12:31:09 | I [o.a.w.p.h.WebApplication ] [17:31:09]: [WicketFilter] Started Wicket version 6.30.0 in DEPLOYMENT mode
INFO | jvm 1 | 2024/01/17 12:31:10 | I [R.S.S.InternalDb ] [17:31:10]: Internal db synchronizer disk cache initialized. State id=e6f443d1-238c-46b8-9303-514028711a28 redundant-provider=internaldb
INFO | jvm 1 | 2024/01/17 12:31:10 | I [R.StateMonitoring ] [17:31:10]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full redundant-provider=system
INFO | jvm 1 | 2024/01/17 12:31:10 | I [o.e.j.s.h.ContextHandler ] [17:31:10]: Started c.i.c.MainWebAppContext@39b24906{Ignition,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2024/01/17 12:31:10 | I [o.e.j.s.AbstractConnector ] [17:31:10]: Started ServerConnector@688ee612{HTTP/1.1, (http/1.1)}{0.0.0.0:8088}
INFO | jvm 1 | 2024/01/17 12:31:10 | I [o.e.j.s.AbstractConnector ] [17:31:10]: Stopped ServerConnector@688ee612{HTTP/1.1, (http/1.1)}{0.0.0.0:8088}
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp:
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big.
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/sun.security.util.DerInputStream.getLength(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/sun.security.util.DerValue.init(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/sun.security.util.DerValue.<init>(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/sun.security.util.KeyStoreDelegator.engineLoad(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/java.security.KeyStore.load(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.security.CertificateUtils.getKeyStore(CertificateUtils.java:49)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.loadKeyStore(SslContextFactory.java:1121)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.load(SslContextFactory.java:291)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:213)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:93)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:171)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:121)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:112)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:367)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:75)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:228)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:428)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.IgnitionServer.start(IgnitionServer.java:1158)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.start(WebResourceManagerImpl.java:351)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at com.inductiveautomation.ignition.gateway.IgnitionGateway.start(IgnitionGateway.java:579)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:301)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2024/01/17 12:31:10 | WrapperSimpleApp Error: at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2024/01/17 12:31:10 | I [g.InternalDatabaseManager ] [17:31:10]: Starting up...
INFO | jvm 1 | 2024/01/17 12:31:10 | I [P.InternalDatabase ] [17:31:10]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2024/01/17 12:31:10 | I [P.InternalDatabase ] [17:31:10]: ... found existing.
INFO | jvm 1 | 2024/01/17 12:31:10 | I [P.InternalDatabase ] [17:31:10]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2024/01/17 12:31:10 | I [P.InternalDatabase ] [17:31:10]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2024/01/17 12:31:10 | WARNING: An illegal reflective access operation has occurred
INFO | jvm 1 | 2024/01/17 12:31:10 | WARNING: Illegal reflective access by com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl (file:/C:/Program%20Files/Inductive%20Automation/Ignition/lib/core/gateway/gateway-8.1.25.jar) to field java.lang.ClassLoader.usr_paths
INFO | jvm 1 | 2024/01/17 12:31:10 | WARNING: Please consider reporting this to the maintainers of com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl
INFO | jvm 1 | 2024/01/17 12:31:10 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO | jvm 1 | 2024/01/17 12:31:10 | WARNING: All illegal access operations will be denied in a future release
INFO | jvm 1 | 2024/01/17 12:31:10 | I [SystemInfo ] [17:31:10]: os.name="windows 10", os.arch="amd64".
INFO | jvm 1 | 2024/01/17 12:31:10 | I [SystemInfo ] [17:31:10]: Validating native library "ignition64"...
INFO | jvm 1 | 2024/01/17 12:31:10 | I [SystemInfo ] [17:31:10]: Validated ignition64 (ignition64.dll)
INFO | jvm 1 | 2024/01/17 12:31:10 | I [SystemInfo ] [17:31:10]: Loading native library "ignition64"...
INFO | jvm 1 | 2024/01/17 12:31:10 | I [SystemInfo ] [17:31:10]: Native library load complete
INFO | jvm 1 | 2024/01/17 12:31:10 | I [g.ModuleManager ] [17:31:10]: Loading modules....
INFO | jvm 1 | 2024/01/17 12:31:10 | I [A.Notification ] [17:31:10]: Alert notification system created.
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.PersistentRecordSecurityLevelConfigService] [17:31:11]: Set up in 4 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.PersistentRecordIdpAdapterConfigService] [17:31:11]: Set up in 7 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.PersistentRecordIdpAdapterMetricsService] [17:31:11]: Set up in 6 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [IgnitionGateway ] [17:31:11]: System properties exist in IDB. Checking if system IdP is set...
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.OAuth2ClientManager ] [17:31:11]: Setup complete in 5 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.InternalDatabaseRememberedSubjects] [17:31:11]: Set up in 7 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.OIDCProviderManager ] [17:31:11]: Set up in 7 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [g.EmailProfileManager ] [17:31:11]: Setup complete in 19 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [G.Manager ] [17:31:11]: Setting up trust list managers...
INFO | jvm 1 | 2024/01/17 12:31:11 | I [G.Manager ] [17:31:11]: Trust list managers setup completed in 20 ms
INFO | jvm 1 | 2024/01/17 12:31:11 | I [c.i.i.g.p.r.ProjectRecordConverter] [17:31:11]: Conversion finished. Elapsed time: 16 ms
STATUS | wrapper | 2024/01/17 12:31:12 | <-- Wrapper Stopped
WARN | wrapper | 2024/01/17 12:31:22 | Timed out waiting for wrapperServiceMain```
