Change a cell's background on a table
I trying to change the background for the selected cell. I'm not able to use the function correctly.
I have the row and column information selected but I cannot enter the column in the function I am using.
I would like to use this function in such a way that it changes any cell that is selected by the user.
Could anyone help me?
Is your dataset JSON? that is the only way this will work.
Once it is in JSON format, you should be able to navigate directly to a cell and set the self.props.data[ROW][COLUMN].style.backgroundColor = "xxx"
You need your data to be in a special format for this to work.
The basic format looks like this:
    'column1': value,
    'column2': value,
    'column1': value,
    'column2': value,
where each dict represents a row, and each key/value pair in that dict represents a column.
To apply style to a whole row, you'll need this kind of format:
    'value': {
      'column1': value,
      'column2': value,
    'style': {
      'backgroundColor': 'red',
note:
Looks like you put that script in a button ?
Why not put it in the table's onRowClick event instead ?
Add a selected_row custom prop to your table to hold the currently selected row and put this in the table's onRowClick event:
def runAction(self, event):
	if self.custom.selected_row is not None:
		self.props.data[self.custom.selected_row]['style'] = {}
	if self.props.data[event.rowIndex].has_key('style'):
		self.props.data[event.rowIndex].style.backgroundColor = 'blue'
	else:
		self.props.data[event.rowIndex] = {
			'value': self.props.data[event.rowIndex],
			'style': {
				'backgroundColor': 'blue'
	self.custom.selected_row = event.rowIndex
The custom prop is used to keep track of the previously selected row, so that you can remove the style.
Thank you.
Your suggestion met what I was trying to do.
It was a question of syntax error
