Change alarm journal/audit log names in Edge?
I'm working on an application in which the same views will be running on both Edge and Standard gateways. The standard gateway will have separate alarm journals and audit logs for each Edge gateway. My preference is to match the audit log and journal names on both the Standard and Edge gateways to simplify my view config.
Any way to rename these, similar to how you can change the Edge Historian name? Am I overcomplicating by not using a single master journal and filtering it in my views?
seconded!
