Hi
Is it possible to change the Priority of an alarm dynamically from a vision window? Everything that I have tried has given me an error stating “Bad_Unsupported”
You can use system.tag.configure. There is an example on interacting with alarms near the bottom.
https://docs.inductiveautomation.com/display/DOC81/system.tag.configure
Note, that doing this will set overrides for the entire alarm.
