Change between two tabs every 30 seconds
I need to automatically change between 2 tabs in perspective.
Can someone give me some ideas on how to do this.
Binding props.currentTabIndex to an expression should work:
floor(getSecond(now())/30)
Thanks for the help.
Works perfect
Can you use the same expression for 4 tabs?
floor(
  (now(1000) / 3000)        // 3000 ms on each tab
  % len({this.props.tabs})  // modulo operator
This will make editing the tab container almost impossible. To fix that, right-click on the binding and disable during the edit. You would need to remember to re-enable when you're finished editing.
