Change default port to 80 and 443
Hi all,
Long story, IT doesn't want Ignition server to be in business network, so they moved it to plc network. Ofc, business people can't access to ignition anymore because of policy, to let them access, they will update policy for each of business people. They recommend to use port 80 and 443 instead of 8088 to let business people access without updating policy.
Question here is there anyway to change port to 80 and 443 without affecting ignition? Port forwarding or any option for this?
BR,
Just go to webserver settings and change it
If your gateway is running Linux as non-root (recommended), you will need a SystemD override to allow use of privileged ports (under 1024).
