Change font by change language in ignition Translation
Hello
In some fonts only one the target language is support(for ex only Russian) so when change language the English the font can’t render target character and text field shows empty in ignition.
I see a lot in other SCADA system that there also be a column for font for each selected language in Translation system. So changing language will also use another font for that particular language.
How does ignition can handle this issue?
Does anyone know how to do this? My Spanish translation takes up way more space and I need the font size to decrease.
You need to combine two font in one with some tools and generate only one font file
