When you first install Ignition, the webpage asks you to select which version to use (Maker/Standard/Edge). Is there any way to change this after the fact, other than reinstalling?
Technically, it’s just an edition parameter in the ignition.conf file. In practice, it’s discouraged because of each edition’s different requirements for modules and gates on certain functionality.
