Hi everyone.
I'm currently making some tests publishing data from Ignition via MQTT, but when I view the message on the MQTT Explorer the topic has changed, and added the sparkplug version on the namespace.
Do you know if there is a way to avoid that?
Try publishing with system.cirruslink.engine.publish: MQTT Publishing via MQTT Engine - MQTT Modules for Ignition 8.x - Confluence
Otherwise, no, if you use SparkPlug you are confined to the SparkPlug namespace/topic structure.
Thanks Kevin, I have a concern about system.cirruslink.engine.publish(). It could be used to publish to a RabbitMQ Broker or it is only designed to operate with Chariot?
It should work with any MQTT broker, and is actually the only way to publish when you aren't using a SparkPlug namespace.
It´s worked. Thanks
