Change Page Automatically Every 30 Seconds
Hello
I want to switch a page every 30 seconds while the project is running in runtime.
So let it automatically switch between pages.
Is something like this possible ?
Thank you.
Vision or Perspective ?
Should the page switch be synchronized between all open clients (ie: show everyone the same page at the same time) ?
Yes, All open client show everyone the same page at the same time. I want to do it in vision
  • make an expression tag that toggles every 30 seconds. Using the gateway time ensures the same toggle across all connections. Specifying [System]Gateway/CurrentDateTime lets it work regardless if you use a client tag or gateway tag.
    floor(getSecond({[System]Gateway/CurrentDateTime})/30)
  • Create a tag that stores the pointer value of the screen you wish to display.
  • Use a client tag change event script, triggering on the expression tag you just made:
windowPaths = [
			   'path/to/screen 1',
			   'path/to/screen 2',
			   'path/to/screen 3',
			   'path/to/screen 4',
			   'path/to/screen 5'
pointerTag = ['[default]path/to/pointer/tag']
pointer = system.tag.readblocking(pointerTag)[0].value + 1
if pointer >= len(windowPaths):
	pointer = 0
system.nav.swapTo(windowPaths[pointer])
system.tag.writeBlocking(pointerTag, [pointer])
Everything is very understandable, thank you .
I just didn't quite understand how to open the page.
"system.nav.swapTo(windowPaths(pointer))"
It looks like a typo. It should probably be system.nav.swapTo(windowPaths[pointer])
windowPaths is a list of paths, and pointer is the integer that selects a specific path from the list.
Why not just
pointer = pointer % len(windowPaths) #edited from len - 1
:winking_face_with_tongue:
Because I started with BASIC back in the 1980s. :wink:
Not only does it look like a typo, it, in fact, is one. Thanks for the catch. Fixed.
1982, with ZX Spectrum and Comodore64...
A Comodore 128 and a stack of Commodore magazines for me. I believe it was followed by some flavor of 286
[gorillas.bas]
Is this a dinosaurs gathering of some kind ?
You (old) people were coding before I was even born !
I prefer to think of us as 'seasoned citizens'.
Heh. I suspect my son (also a EE, but not interested in coding) is older than many of you (32) .
As for me:
1978, HeathKit H-8, 8080 machine language via its octal keypad and readout. Moved up to integer BASIC (no strings) on a dumb terminal soon after.
Pft, I'm way older than that! I'm 35 or 36; I'm so old that I can't remember :smile:
Nibbles
86 ?
Also, always wanted to ask... any relation to this other australian Minchin dude ?
I think I'm related, some distant cousin or something. I'm sure my dad or uncle know. We have a book of Minchins somewhere haha
I think the -1 in the mod is incorrect and there shouldn't be any modifier. Once your at index 3 in the list you'll go to index 0 instead of the last window in the list. pointer = pointer % len(windows) works. Just wanted to clarify in case someone sees it and tries to use it.
Oops, yes, you're right. I had that originally but "incorrected" it later :confused: I'll fix my reply, cheers
