Hi all. I am trying to change the background image of a flex container based on a tag value. Any ideas on how to do this. I'm striking out.
Add a binding to the backgroundImage property.
Make it a tag binding, and point that to your tag.
Add a transform:
- if you have only a handful of possible values, use a map transform
- if you a lot of possible values, use either a script transform to programmatically evaluate the image path, or use a lookup expression to fetch the image path from a dataset.
Thanks, i didn't know you could have a style Output Type. Tansform it is. Thank you agian.
