Change series color of chart from script
Hello, is it possible to change the series colors of a Chart object from a script? ie. a way to control the colors of the plotted data from a script?
Yes, the series color property is just a color array. Here is how you can set it from a button:from java.awt import Color colors = [Color.green, Color.yellow, Color.red, Color.blue, Color.orange, Color.magenta, Color.gray] event.source.parent.getComponent('Chart').seriesColors = colors
I seem to be missing something, perhaps the identifier for the dataset or something. I’m getting the following error when trying to recieve the current set of colors:
AttributeError: instance of ā€˜com.inductiveautomation.factorypmi.application.components.PMIChart’ has no attribute ā€˜seriesColors’
I am referring to the bar chart component since it has a property called Series Colors. The classic chart doesn’t expose the series colors as a property. You can use the following code for your classic chart:from java.awt import Color colors = [Color.green, Color.yellow, Color.red, Color.blue, Color.orange, Color.magenta, Color.gray] chart = event.source.parent.getComponent('Chart') chart.getDynamicProps().get("Data").getRenderer().setSeriesColors(colors) chart.createChart()Just replace the ā€œDataā€ with your dataset you want to change the series colors on.
I am running Ignition 7.5.5 and using your script for changing seriesColor on a bar graph component results in an error saying ā€˜seriesColors’ is no attribute.
It should work, are you sure you’re getting back the correct bar chart component when using getComponent()?
Your right, James.
Thanks.
