Change single label color in xy Chart
Good morning,
I would like to set the labels forecolor of the Y chart differently in an xy chart in Perspective.
In particular I need to change the color from white to red if I have a bool condition.
Should be possible?
Create an expression binding on,
yAxes.0.appearance.labels.color
The expression binding would look something like,
if({[default]myBool}, "red", "white")
Hi @Transistor, actually I would like to change the single label, I have something like this in the Yaxis
For example I need to turn red only the 04 or 06
If you check with your browser's Developer Tools I think you will see that there is no unique identifier on each of the labels. That implies that it wouldn't be possible to target one of them for a color change.
Since it's an XY Chart you might be able to add another datasource and draw a triangle closed shape to point at the relevant label from inside the chart area.
Yes you're right, I check with the Developer Tools and I see nothing, but maybe I was missing something.
This is an interesting thing, but you mean I could add something like an icon connected to the label or add a new series with the same Yaxis?
This one. It should be easy if the X-axis render mode is set to value. For category or date rendering it wouldn't work. (Maybe it would for date if it accepts time values as well.)
In my case I have catergory in the Yaxis and date in the Xaxis, so it looks quite hard to do. That's a pity.
Thank you for your help :+1:t2:
Found an easy solution. Category axis label support in-line TextFormatter.
Example with sample XY chart data.
@Ujwal_Wankhede, this is so simple! I've already implemented it
Thank you too for the help
