Change text color for disabled input
I’m using Ignition 7.6 on Windows 7.
On the numeric input (and text input) boxes when the “Enabled” property is set to false, it makes the background a light grey color and the foreground a slightly darker grey color. Is there anyway at all to change these default colors? I noticed that tere is an “Editable” and a “Protected Mode” field in the “Behavior” area, but I can find no way to read the current values of those in the expression area or else I would use that to set the color of the foreground.
Anyone run into this and know how to either change the default colors of non enabled objects or access the current value of “Editable” and/or “Protected Mode”?
I would also like to know the answer to this question. Changing default text appearance of disabled text objects.
These forum posts may point you in the right direction:
