Is it possible to change the binding of a property on the change of another?
Let’s say I have:
- 3 value properties:
a: 1
b: 2
c: 3
- A dropdown list with values: [a,b,c]
- A label which is bound to the dropdown list with a transform:
- if the selected dropdown is a, show value of a.
- If the value is b, show value of b
- If the value is c, show value of c
Now, if select a in the dropdown, the label will show the value of a. Same with selecting b or c. All good.
However, if the dropdown is selected as a, and the value a itself changes, the label will not update, because it’s bound to the value of the dropdown list.
Ideally, what I would like is:
- If the selected dropdown value is a, then the label is bound to property a
- If the selected dropdown value is b, then the label is bound to property b
- If the selected dropdown value is c, then the label is bound to property c
Is this possible?
I’ve achieved this using value changed scripts but it’s become quite messy and I’m hoping for a cleaner solution.
Any help would be hugely appreciated.
I advice you put these 3 props into an object (altho it works on the base props too)
bind your dropdown options to this object so that the label/values stay updated too
return [{"value":x,"label":x} for x in value]
then you can easily acces the dynamic attribues with
[] like so
return self.view.custom.customValues[value]
if you want the label to update in real time when the customValues updates and/or the dropdownvalue you will have to use a structed expression binding so you can bind those two props so it will execute when any of them changes
edit:
note: you might want to put in some logic on the label incase the dropdown value is null to return a default message or something, else it will show a null error
if value != "":
return "Nothing is selected"
or in one pythony line:
return self.view.custom.customValues[value] if value != "" else "Select something"
Could just use if value, so it handles both None and empty strings.
Hey @victordcq, thank you very much for the solution! That’s worked perfectly for me. Seems like expression structure bindings were the trick I needed!
Also nice to know you can bind the drop options to an object property using python dictionary syntax, another thing I didn’t know was possible!
