I have found the UI borders feels very old and small, particularly when using touch devices, so I have tried to change the java UI theme.
I have added the following piece of code into the client event script:
from javax.swing import UIManager
theme = "com.sun.java.swing.plaf.windows.WindowsLookAndFeel"
UIManager.setLookAndFeel(theme)
And it partially works, I have been able to change the windows borders as you can see in the screenshots attached
New theme:
[attachment=0]new.PNG[/attachment]
Ignitions theme:
[attachment=1]old.PNG[/attachment]
However after setting the new theme I am unable to open any window, it throws me an error related with the deserialization. This is the error message:
[code]com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element ā<cā
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:952)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:833)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:151)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:339)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:271)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:213)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:422)
at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:460)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:193)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:424)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:815)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:362)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:352)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:134)
at sun.reflect.GeneratedMethodAccessor176.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:430)
at org.python.core.PyObject.call(PyObject.java:387)
at org.python.core.PyObject.call(PyObject.java:391)
at org.python.pycode._pyx5.loadMenuWindows$14(module:shared.sepp.st_controlVentanas:302)
at org.python.pycode._pyx5.call_function(module:shared.sepp.st_controlVentanas)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:120)
at org.python.core.PyFunction.call(PyFunction.java:307)
at org.python.pycode.pyx338.runAsync$1(event:mousePressed:18)
at org.python.pycode.pyx338.call_function(event:mousePressed)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call(PyFunction.java:376)
at org.python.core.PyFunction.call(PyFunction.java:371)
at org.python.core.PyFunction.call(PyFunction.java:361)
at org.python.core.PyFunction.call(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:639)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientSystemUtilities$2.run(ClientSystemUtilities.java:350)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.NullPointerException
at com.incors.plaf.alloy.a.i.a(Unknown Source)
at com.incors.plaf.alloy.df.a(Unknown Source)
at com.incors.plaf.alloy.df.(Unknown Source)
at com.inductiveautomation.ignition.client.util.gui.SegmentButtons$SegmentButtonBorder.(SegmentButtons.java:196)
at com.inductiveautomation.ignition.client.util.gui.SegmentButtons$SegmentToggleButtonUI.installDefaults(SegmentButtons.java:188)
at javax.swing.plaf.basic.BasicButtonUI.installUI(Unknown Source)
at com.incors.plaf.alloy.AlloyToggleButtonUI.installUI(Unknown Source)
at javax.swing.JComponent.setUI(Unknown Source)
at javax.swing.AbstractButton.setUI(Unknown Source)
at com.inductiveautomation.ignition.client.util.gui.SegmentButtons$SegmentToggleButton.updateUI(SegmentButtons.java:162)
at javax.swing.AbstractButton.init(Unknown Source)
at javax.swing.JToggleButton.(Unknown Source)
at com.inductiveautomation.ignition.client.util.gui.SegmentButtons$SegmentToggleButton.(SegmentButtons.java:145)
at com.inductiveautomation.ignition.client.util.gui.SegmentButtons.addSegment(SegmentButtons.java:53)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable$AlarmCharts$SimpleRangePicker.(AlarmStatusTable.java:1807)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable$AlarmCharts$TrendChart.(AlarmStatusTable.java:1325)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable$AlarmCharts.(AlarmStatusTable.java:1304)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable$FooterPanel$UtilityPanel.(AlarmStatusTable.java:2747)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable$FooterPanel.(AlarmStatusTable.java:2225)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable.initLayout(AlarmStatusTable.java:400)
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable.(AlarmStatusTable.java:315)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.startSubElement(ComponentDeserializationHandler.java:72)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:830)
⦠62 more
Ignition v7.9.0 (b2016101208)
Java: Oracle Corporation 1.8.0_121
[/code]
Have anyone tried to achieve this? Am I missing something?
Regards
