Change words on Numeric Field edition menu
Hello!
I would like to know if there is a simple way to change the names on the Edit Numeric Field Menu
  <div class="ia_numericEntryFieldComponent__modal_buttons"><button
        class="ia_button--secondary popup-not-draggable"><span>Cancel</span></button><button
        class="ia_button--primary popup-not-draggable"><span>Apply</span></button></div>
Aply to Aplicar and Cancel to Cancelar
Any ideas welcome.
If not possible I may start using Ignition Perspective translation system.
I imagine that this is the correct way to do this.
You'd be correct. This is exactly what the translation system is designed to do.
