Hi, I have recently discovered Embr Charts and I wanted to learn how we can change colour of Radial Bar under Apex Charts.
Under options, select the fill property
you can then assign colour per section
"colors": [
"#F44336",
"#E91E63",
"#9C27B0",
"value"
"opacity": [],
"type": [],
"gradient": {
"gradientToColors": [],
"opacityFrom": [],
"opacityTo": [],
"stops": [],
"colorStops": []
"image": {
"src": []
"pattern": {
"style": []
249 is the total of all quantities in the dataset…
formatter is used for when you want to format the text or value in this case.
Is there any way to change ?
Like display a different value or change format ….
dataLabels – ApexCharts.js - refer to this link for more info on formatters
