Current setup: Dashboard that links to other projects in many different gateways. When my project is opened from the dashboard, the dropdown on the dock to the left is set to value 1 by default which has different tabs than values 2-5. Each value has different tabs for a specific machine (1-5). When on the main dashboard, you can select exactly which machine you want to open from the start. However, even if I select machine 2 from the dashboard, the dropdown will default to value 1. This results in the first window opening on startup correctly (machine 2 overview) but if an option is selected in the dock it will take you to a tab for machine 1. You have to change the dropdown selection to your desired value before changing tabs when the project has just been opened.
Want: Setting the dropdown value based on the machine selected from the dashboard so you do not have to change the dropdown value when opening the project directly for machines 2-5. I looked into startup scripts but those run before any windows are opened. Any ideas?
P.S. sorry for the abstract/unclear explanation. I can not provide many details or any screenshots so if there are any clarification questions please let me know.
