We are attempting to create an HMI in which a technician can fully commission the unit. One of the problems we are tackling is to adjust the static IP settings of the HMI/Controller once it arrives onsite. Is there any way to modify the host system’s IP address (gateway’s address) that already exist?
Currently the only approach that seems feasible is to call some kind of CLI command (the ignition edge gateways are deployed on linux systems if that matters). We are hoping there is a more out of the box solution that exists to this problem.
