Changing Ignition Edge Project Name
Hello, may I know can I change the Ignition Edge Project Name ? I 'm not able to as the column greyed out. I’m using Ignition Edge version 8.0.10. From the user manual is stated that as of version 8.0.8, the Edge project can be renamed. Thanks.
Did you ever find a solution to this?
There may be some follow-up here needed in the docs. I can see where it does suggest that you can change the project name, but editing of it is disabled. In 8.1.11, editing the built-in realtime tag provider was added (and you can change the name of that provider). The project name is still fixed at “Edge” (though you can customize the title).
