Currently I want to change the format from year-month-day-hour-minute-second and just have hour-minute-second independent from the other information. is this possible?
Where is this t_stamp? In the database?
I want to use the current time given by the system (IGNITION) to make an expression tag where if the value of time
is for example:
time<5:00:00 then =shift 1
time<13:00:00 then =shift 2
time<21:00:00 then =shift 3
I already have the time in a tag but can’t seem to get the expression tag to work
Try using the Date expression functions.
The one I linked is dateIsAfter which returns a boolean.
Try this expression:
floor(((dateExtract(now(1000), 'hour') + 3) % 24) / 8) + 1
Thank you
I’ll try this
Hi, I used this code:
if({[.]24H Time} < ‘5:00:00’, {[.]SHIFTS}=3,
if({[.]24H Time} < ‘13:00:00’, {[.]SHIFTS}=1,
if({[.]24H Time} < ‘21:00:00’, {[.]SHIFTS}=2,
if({[.]24H Time} < ‘24:00:00’, {[.]SHIFTS}=3, {[.]SHIFTS}=0
but my SHIFTS tag is currently changing between 0 and 1 when it should just stay in 1 and then change over to 2 after 13/1pm
Consider using timeBetween() to do your comparison. timeBetween() won’t work with 24 hour time, but it’s easy to use.
Also, don’t give it the option of putiing in a zero when zero isn’t supposed to be an option.
Here’s an example using timeBetween()
if(timeBetween(now(),"5:00:00 am","12:59:59 pm"),1,
if(timeBetween(now(),"1:00:00 pm"," 20:59:59 pm"),2,
3
I will try this right now.
This worked!!! Thanks so much for the help
This is Perfectly working with time comparison in Expression.
if(timeBetween(now(),“7:00:00 am”,“3:30:00 pm”),‘A’,
if(timeBetween(now(),“3:30:00 pm”," 11:59:59 pm"),‘B’,
‘C’
Thanks Jordan.
