Chart component showing error with no apparent issue
I have a PLC where I'm pulling the data from arrays and inserting it into a dataset one of the columns is a date but its put out as a string and Ignition will not format it correctly so I have to import datetime, use datetime.strptime() and then put it in a table, so good so far.
Now I'm trying to chart the data so I formatted the table with the following script:
from datetime import datetime
column = 0
d_column = 22
x = []
series = {}
for row in value:
        y = round(row[column],2)
        z = str(row[d_column])
        series = {'Pressure' : y, 'time' : z}
        x.append(series)
Series look something like:
data = [{'time': '2026-10-12 15:59:00.0', 'Pressure': 5114.77},{...},...]
The issue is that the component is still showing Error but there is nothing that tells me what the error is, there is nothing on the Property panels. All I see is this:
Generally speaking, Ignition expects datetimes to be either Java Date objects or integer epoch milliseconds, as in something like 1791925266000. Strings cannot be unambiguously parsed into dates without external knowledge of the exact input format.
If you're starting from a string, you can use system.date.parse to turn a string into a Java Date object given a known string format, and then use the time property or system.date.toMillis to convert to that epoch milliseconds representation.
Your script is a bit incomplete/unclear, though - what is the actual "shape" of the data you're trying to render on the chart?
So I had another script to move the tag dataset [100 rows, 23 cols] to the component table I do this to be able to format the time. Original time is 13.10.2026 13:16 I just changed the formatting to use system.date.parse with no issues, when I try to bind the data directly from the table to the chart it doesn't like it so I figured I had to format it with the list of dicts as above. The only missing part of the script is the definition and the return, which is x at the end.
At the end I'm able to change the date to epoch in the chart but still shows same error on the faceplate.
