Chart cubic interpolation
Hi, I took an example from following site:
https://www.chartjs.org/samples/latest/charts/line/interpolation-modes.html
and I wonder if chart component offers similar functionality. I have a simple chart with one value and I would like to make it more pleasant to an eye by having the line smoothly drawn. For example, in the picture below, I have a green line and i want it to be drawn like the red line.
Thanks for any advice
You can add XYSplineRenderer even though it isn’t in the list of renderer under Dataset Customizer.
I would do something as below:
from org.jfree.chart.renderer.xy import XYSplineRenderer
chart = event.source.chart
plot = chart.getXYPlot()
renderer = XYSplineRenderer()
# The Precision makes curve smooth ! You can play with changing the numbers.
renderer.setPrecision(15)
plot.setRenderer(renderer)
I have this script on the mouseClicked Event Handler of the chart which changes the chart to curve when I click on it. Best Idea would be to have it on ConfigureChart Extended Function !!
How would multiple datasets or pens change the code? Thank you!
If you’re adding a new series (dataset), code won’t change as long it’s the same plot because you’re rendering to the plot which includes all series.
Oddly, the second dataset wouldn’t correctly render for me. I had to use this:
	plot = chart.getPlot()
	rendererCount = plot.getRendererCount()
	for i in range(rendererCount):
		plot.setRenderer(i, renderer)
Also this completely breaks if you use subplots, as the plot type goes to CombinedDomainXYPlot.
This seems to work for me:
	# Get plot type
	plotType = plot.getPlotType()
	if plotType == 'XY Plot':
	if plotType == 'Combined_Domain_XYPlot':
		subplots = plot.getSubplots()
		for subplot in subplots:
			rendererCount = subplot.getRendererCount()
				subplot.setRenderer(i, renderer)
I was, without a doubt, expecting something like this from you !!
Got much to learn from you through this forum.
Thank you Jordan,
I have tried your code and it makes all lines smooth as intended.
Problem is, that all lines are now colored red. See picture below:
Without the code the chart looks like this:
How can I set different colors to those lines and also get rid of those shapes attached to them?
Try this...
from java.awt import Color, Font
chartColors = [Color.BLACK, Color.GREEN, Color.CYAN, Color.orange, Color.GRAY]
`# The Precision makes curve smooth ! You can play with changing the numbers.`
#This will hide the shapes !
renderer.setBaseShapesVisible(0)
`# Get plot type`
#set dynamic Colors -
for i in range(plot.getSeriesCount()):
	plot.getRenderer().setSeriesPaint(i, chartColors[i %(len(chartColors))])
Anyway to do this in Perspective?
