Chart stuck not showing the changes in the tag value, Edge historian not working?
Hi
I am using one tag to plot the chart and it has History enabled Edge historian , it was working earlier but now seems to be stuck at the same value and shows the plot as if the value is not changing but my speed is changing a lot
Is your system licensed? If not, is the trial expired?
I am using 2 hours trial which I reset after 2h time has elapsed , I am able to read the real time engine speed on the LED display however the historian shows the same values and chart also stuck at the same value
