In charts, is there a way to rotate the axis name?
• Right click on the chart, and select chart customizer
• Select the Y-Axes tab, and select the Axis in the left list box
• In the properties pane, adjust the Axis Label Angle property. (Note: the angle adjustment uses radians instead of degrees)
Result:
