Check box scaling
The Check Box component does not scale size properly.
Can you give more details about this, like a screenshot of what you are talking about and any information about how the check box is configured? What is its layout settings? etc.
I see that the actual checkbox doesn’t get bigger or smaller. It is a fixed size. I think it is designed that way.
If you want a checkbox that scales its size up and down you could make your own custom one as a template with Ignition components and some scripting.
I am also dealing with this issue. We have an Alarm Status Table and want to increase the size of the checkboxes to the left of the table entries. I was told by Ignition tech support that we are not able to do this because of the limitations of Java Swing. Can you explain how you would make a custom one as you suggested?
