I’ve got an Ignition install that should have a SQL bridge limited license, but during a move of one of our machines my coworkers did a hard-drive shuffle without knowing what it would affect. The end result is that now I’m not sure if Ignition is running on the same chassis it was originally installed on. The computer chassis that were involved are all identical models so I am unable to tell if it is in fact different.
Is there a place where the license.ipl file that is uploaded during the licensing process is saved on the computer, and is it possible that Ignition would un-license itself if hardware changed? I know it is common to tie licenses to a piece of hardware like a network adapter or hard drive serial number.
