Check String Parameter to Enable/Disable Tag
I have a string parameter that is used in the OPC path of a tag. I want to disable the tag if the parameter is not provided (empty). My binding on the enabled property of the tag looks like so:
!( isNull({Read_Tag}) || {Read_Tag} = "" )
I'm not sure if an empty string returns "", or Null, so I used both.
I get a configuration error on the tag:
Error_Configuration("Bad_AttributeIdInvalid: The attribute is not supported for the specified Node.")
Is there something wrong with the binding?
You can't use expression language in the binding of the enabled property, unfortunately. Fortunately, you CAN just use {Read_Tag} and it will cast any non-empty string values of your property to "True"
If that's the case, it really should stop highlighting expression statements as if the expression syntax applies. For instance:
"if" should not be highlighted as a function if this is not the expression language.
