Hi I encountered an issue where I can’t seem to open the choose component property window when clicking on the choose component property button inside the event handler/navigation tab when you check the pass parameter checkbox and tried to add a parameter. I’m using Ignition Version 7.4.1 (b906).
Make sure you’re not double-clicking into the property cell. Just selecting it is all that’s needed to use the property selector. Otherwise, we might have a legitimate issue.
On another note I recommend upgrading to 7.4.2 especially if you are using SQLTags History, given that there was an issue with it in 7.4.1.
