Cirrus Link MQTT Engine can not handle all namespaces
Hi. I’m using Ignition Makers Edition (8.1.23) with MQTT Engine (4.0.18) to handle some topics of my home IoT devices. I have 8 custom namespaces defined (with all default namespaces disabled). If I add another custom namespace, some of the previous definitions cease to update the Ignition tags. Newly added namespace works OK, although the log entries say that subscription to the new topic failed. I have tried this with several new topics (all of them as JSON payloads), but with no success. I’m using the mossquito MQTT server. I have also tried to install the MQTT Distributor module and configure it as additional MQTT server in MQTT Engine settings, then configure some of the IoT devices to use this server, which did not solve my problem.
Cross Linking Cirrus Link's answer:
