We're using an Ignition Edge in combination with the Cirrus Link MQTT Transmission to transfer our tags & UDTs over MQTT to our Ignition server. However, we have a problem with transferring the UDT parameters.
In the Ignition Edge, we have a UDT called "Test" with 2 parameters, as can be seen below:
In the Ignition server, we receive this "Test" UDT, but none of the parameters are present here:
As for the MQTT Transmission Transmitters settings, the settings for UDT are configured as follows:
